Machine Vision
Getting Kernel32.dll procedure entry point errors when trying to load NI-IMAQ v2.6.1
Here is a copy of what appears in the Error Log:
Application popup: setup.exe - Entry Point Not Found : The procedure entry point GlobalGindAtomA could not be located in the dynamic link library KERNEL32.dll.
I have also recieved the following:
Application popup: autorun.exe - Entry Point Not Found : The procedure entry point TerminatePsocess could not be located in the dynamic link library KERNEL32.dll.
and:
Application popup: autorun.exe - Entry Point Not Found : The procedure entry point IsCadReadPtr could not be located in the dynamic link library KERNEL32.dll.
FYI - software loaded onto a IDENTICAL machine (hardware) w/o difficulty.
(3,636 Views)
Is the other machine "IDENTICAL" in terms of operating system, software, etc? Does the error occur when trying to acquire an image in Measurement & Automation Explorer (MAX), as well as in your programming environment? Have you tried reinstalling the NI-IMAQ driver? Has this system always exhibited this problem, or are these errors a new phenomenon?
Dawna P.
(3,636 Views)
