Machine Vision
Get 16-bit unsigned data from an image
I got 16-bit grayscale UNSIGNED images from IMAQ framgrabber . I am trying to get the data of the image. However, most application of LabView support 16-bit signed. I used IMAQimageToArray to convert image to data. However, if my image data is between 0-32767, the result from IMAQimageToArray is 0-32767. If my image data is between 32767 to 65535, the result from IMAQimageToArray still be 0-32767!!!!! If my image data is between 0-65535, the result will be shifted dawn to -32768 to 32767.
The problem is that when I get the result between from 0-32767, I will not be able to know that the real data is 0-32767 or 23768-65535!!!! How can I get the real image data from 16-bit unsigned grayscale image?
The program still behaves the
same with TIFF format image.
(3,866 Views)
Hello Kritsada,
I don't know if I have understood your problem correct,
but have you tried the following?
Select the Functions Palette, then "all Functions" ->
"numeric" -> "conversion". There you find a function that converts data to the unsigned 16Bit form. If you put this function behind the "IMAQimageToArray.vi", the data should be converted from I16 to U16.
I have attached a very simple example...
Peter Weber
NI Germany
(3,866 Views)
Hello Peterguy,
Thanks for your answer.
However, my problem can not be solve with those convertion functions. it is quite complicated to explain. Therefore, I have attatched 3 example images . They are 16-bit UNSIGNDED images which actually 12-bit image but shifted to the left 4 bits(to make 12-bit image to 16-bit image). Therefore , the value of the darkest pixel should be 0 , the value of the brightest pixel should be 65520( or FFF0).
The image"dark4m1.tif" is a dark image..
The image"White250m.tif" is a bright image...
The image"BlackWhite.tif" is a bright image(White250m.tif), but I change the first pixels Black and the second pixel to Gray..
After you use IMAQimageToArray.vi , you will see that....
For
"dark4m1.tif", IMAQimageToArray.vi will give the value for the darkest pixels = 0 . If you look at the HEX code of the image, you will find the darkest pixel value = 0.
For "White250m.tif" ,IMAQimageToArray.vi will give the value for the brightest pixels = 32752. If you look at the HEX code of the image, you will find the bright pixels value = FFF0 which is 65520
The range of Black to White from the HEX code is 0-65520, but the range of Black to White from IMAQImageToArray is 0-32752. !!! ?????????????????.....
Now, consider the last image.
Then ,from the HEX code of the image,you will see Black pixel = 0,Gray = 32768( HEX=8000) White = 65520 (FFF0). However, the pixel value from IMAQImageToArray.VI will be ....Black pixel = -31280, Gray =0, White = 32752 ......!!!!!! ...???????? now, IMAQimageToArray does not give Black=0 anymore....
The problem is that ..... if I get an array from IMAQimageToArray which has range from 0-3275 , How can I know that the image
is Black(0)-Gray(8000) or Gray(8000)-White(FFF0)....?
Thank you,
Kritsada
(3,866 Views)
Hi Kritsada,
your problem sounds really strange...
For Example: The "FFF0"-Value in your Bright Image should be read as -16(signed format), or 65520 in unsigned format...
But NOT 32752! (32752 is "7FF0" in Hex.)
Perhaps you can post your VI, so that I can check the files with your Code?!
Regards
Peter Weber
NI Germany
(3,866 Views)
