Machine Vision
Flat-Bed Scanner Driver Needed
Has anyone used LV to control a flatbed scanner? I need to automate the scanning process in LV by scanning and saving to an image file which I then will analyze using VBAI and LV. I am looking at HP scanners using the USB port but this doesn't have to be the case. Any info that you can provide in this area will be great. Thanks.
(3,070 Views)
Hello Scan-man,
You can do that using the activeX library, and can call them in LabVIEW. Apart from that I found this link to the knowledgeBase and to the DF. This may help you.
Thanks and good luck with everything.
Regards
Nikhil A.
(3,058 Views)
