Machine Vision
Firewire 1394 camera problem
Hi NI community,
I want to use my guppy camera (FireWire 1394 connection) from allied vision, but I bumped into a connection problem. I use this FireWire card (http://www.belkin.com/IWCatProductPage.process?Product_Id=428618), but according to the installation check this card is installed well.
When I plugged in the camera and started Vision Builder AI 2010 it wouldn't recognize my  camera so I went searching for the problem which I did find at my hardware properties. When I go to the properties of the camera it says 'This device won't start. (Code 10).
I've been looking for a solution, but I'm not a genius when it comes to this. So is there maybe someone who can help me with this problem.
Regards
Ruts
(9,399 Views)
Scott here with AVT... I see you wrote also to AVT technical support...  there you mentioned generic driver... in fact you need NI driver  please see
https://www.ni.com/en/support/documentation/supplemental/06/acquiring-from-firewire--cameras-with-ni...
(9,393 Views)
Thank you for the fast reply
When I tried to install NI-IMAQ for IEEE 1394 cameras 2.0.1 I get this message in the installation proces (see attachement). When I saw that I thought it was already installed on this computer, but when I checked my NI MAX (see attachement) I couldn't find it under software. I really thought that my problem was solved in no time with your solutionn but it seems I ran into another problem.
Do you or someone maybe know the answer on this one?
Regards
Ruts
(9,384 Views)
I managed to install NI-IMAQ IEEE 1394 after all. The software does show up in my NI-MAX, but the camera still doens't appear in devices and interfaces.
(9,359 Views)
According to a manuel there should be a direction under the devices and interfaces called "NI IMAQ IEEE 1394 devices" which can be expaned to see my FireWire camera. I can't even see that direction in my NI MAX which you can see in the attachement.
Does anyone know how to solve this
Regards
Ruts
(9,354 Views)
Accepted by topic author RutsT
Here's an update after a whole day searching for a solution.
I currently see the my IEEE 1394 PCI card (older card from 2001) which has a OHCI Complaint driver (I guess that's the default driver from windows). I also see the camera under my hardware but it shows with a little error sign which says "Device won't start (Code 10)". I also installed the NI driver which I can see in my NI MAX, but not under hardware at my IEEE 1394 PCI card.
I also discovered that when I had an unibrain driver installed (together with the OHCI complaint driver) my camera simply didn't show up in my hardware.
Do I maybe have to link the NI driver with my IEEE 1394 card (I tried to do this but I didn't succeed)?
In the attachments you find a picture that shows my hardware.
EDIT:
Don't bother the problem is solved. I think it did need some time after deinstalling the unibrain driver to see the cam in NI MAX. For those who have the same problem: Just install the default driver from windows ( OHCI Complaint ) and install the NI IMAQ for IEEE 1394 driver (think my problem was the additional Unibrain driver).
Regards
Ruts
(9,339 Views)
