Machine Vision
Firewall Transversal.
Quick question guys,
Do you know if Dalsa cameras support that function? Also, which version of Imaqdx do I need to run it?
(3,883 Views)
Spaaw,
I've taken a look at Dalsa's website. It appears there are many types of camera connections. Do you have a particular camera in mind? http://www.teledynedalsa.com/mv/products/cameras.aspx
My impression is that firewall traversal seems like a behavior independant of the camera based on this wikipedia article. What is your rationale for needing this sort of behavior?
Ben D.
(3,874 Views)
I have a CR-GEN0-C6400 camera.
I need to get around the firewall on the network that's blocking all incoming data.
Peter
(3,867 Views)
Hi Peter,
I have a Genie M640-S3 with a semi-recent firmware and it appears that the camera _does not_ support the optional GigE Vision spec firewall traversal feature (the "FirewallTraversal::Supported" feature in IMAQdx indicates this capability).
As an alternative, you could use one of the several NI GigE Vision cards that can make use of our High Performance driver. Because of the low-level nature of the driver, GigE Vision traffic can be received even when a software firewall is in place.
Eric
(3,860 Views)
