Machine Vision
Find the Defect
I attched three images in which I want to find out the defect.
I applied some of mechanism but it doen't work and I am new in Labview and Vision Assistant
So plz help me and suggest me which mechanism should work on it in Vision Assistant...
In Attched Images I used a glass to detect the side Defect of the Circle, So Mechanism must be applies on the glass not in middle images
In copy of 1 and copy of 2 images show you what I want to find as a defect..
Plz Help me....
Thank You..
(3,208 Views)
First of all I would recommend to have a better contrast on your images. The difference is not significative between the background and the defect.
Then you can try the contour extraction functions.
Regards
(3,194 Views)
