Machine Vision
Fill Holes and Particle Filter Error
I posted a question about an error I was getting doing a particle filter operation some days ago on the VB forum and got no response so I am reposting here under Vision. To illustrate the problem I have attached some VB code to show the error described below under PARTICLE FILTER.
I have also found another problem with filling holes in a Binary image, which is also illustrated in this code. When I try to fill holes on my binary image it turns the whole image black! I have tried thresholding before the operation, inverting the image etc, with no luck! All I get is a fully black image! Again this code pretty much follows the example given in the documentation!
All the files for the sample code are in one attached zip f
ile
PARTICLE FILTER
The following code is given in the IMAQ Vision documentation for conducting a particle filter
Dim i As New CWIMAQImage
Dim data As New CWIMAQParticleFilterData
' Select particles that contain less than 100 pixels or
' more than 300 pixels and remove them.
data.Add
data(1).Parameter = cwimaqParticleArea
data(1).MinValue = 100
data(1).MaxValue = 300
data(1).Exclude = True
' Perform the particle filter operation and
' store the result in i
CWIMAQVision1.ParticleFilter CWIMAQViewer1.Image, i, data, True
However it generates the following error for me when doing this on a binary image.
Run time error ‘438’ - Object does not support this property or method which is generated by the line in the code
same is also true for the line
but not
Has the syntax been changed from that in the documentation?"
(3,141 Views)
It appears that the format is slightly different from what is listed in the manual. You will need to use:
data(1).Range.min = 4
data(1).Range.max = 300
I have attached modified code. Also, as for the fill holes, I made sure to threshold and view the image in a binary palette,and the blobs are not being deleted. Take a look at the code and let us know if you need more help!
Best Regards,
Chris D
NI Application Engineer
(3,141 Views)
