Machine Vision
File Dialog problem
Hello!
I'm trying to use "IMAQ Read Image and Vision Info" and "IMAQ Read File" to open an image file, but I'm having 2 problems with them.
If I select an image in the dialog box that appears, and click the "open" button, it will appear an error message saying that I cannot perform that operation in an individual file, problem that I avoid by clicking in the "current folder" button instead of "open". Any better solution?
After clicking in the "current folder" button, it appears an error message telling me that file acess is denied, and I don't see why, because I didn't save it with any permissions and in its properties it can be read... Any help?
Thanks in advance!
(3,343 Views)
Any help?
I'm needing it urgently... Smiley Sad
(3,335 Views)
Problem solved!
I now use normal LabVIEW file dialog to browse to the path and then the IMAQ vi's to open the file by it's path, and that's it 😉
Thanks to Wiebe!
(3,333 Views)
