Machine Vision
Fast RGB to HSL convertion?
How is it possible to speed up the software convertion from RGB to HSL?
I found that this is a very time demanding task (about 70 msec on my PC). Is it possible to have such a convertion in less than 20 msec? Maybe a multiprocessor computer could solve the problem?
(4,536 Views)
Hi andrea,
I need some more information in order to better help you. For example:
  • In which language are you programming? LabVIEW, CVI, VB6?
  • Which function are you using? I suppose it's the IMAQ Cast Image....
If you're working in LabVIEW, the following example could be a common benchmark test:
How Do I Convert a Color Image to Grayscale?
Hope this helps,
Best Regards,
Fabio
Fabio M.
NI
Principal Engineer
(4,515 Views)
Hi Mario,
 I am working with LabView+Vision 8.0. Actually I need to apply a color threshold with HSL as "method". I found that this thresholding takes a long time to perform the task if the input image is an RGB-image; I guess that this is because this function first convert the image in the HSL-format, in fact casting the image first in the HSL-format and passing this HSL-image to the color-threshold function results in very little time demand from the thresholding function, but it is now the cast-image function that takes a long time to perform (about 60-70 msec on my PC).
Thank you for any kind of suggestion.
(4,506 Views)
