Machine Vision
Extract metadata from jpg? (date picture taken)
Does anyone know how (or have a VI) that can extract metadata from jpeg images?  Specifically I am looking for "date picture taken" but it would be nice to have other tags as well.
Jeremy
Message 1 of 9
(78,671 Views)
Hi, Jeremy,
You can't get this info in Vision "directly".
Otherwise there are two possible ways:
1. Use third-party utility or library, for example ExifTool by Phil Harvey. Call it with your image, parse the output, and you will get info.
2. Read Exif specification, and parse your jpeg file yourself. More work, but you will stay independend from third-party code.
Andrey.
Message 2 of 9
(78,662 Views)
Hi Andrey,
so I guess there is no built-in solution within labview.  I just did a search for the EXIF IFD attribute in the files I am interested in but they did not show up.  I am thinking it may be stored somewhere else.  The Windows file system can see and display this info (see jpg attached).  I need to rename my files according to the date/time stamp and I don't want to do it one by one.
If you or anyone else can help with a VI that would be enormously helpful.
Thanks again,
Jeremy
Message 3 of 9
(78,640 Views)
If you are willing to settle for the last modification date, you can get it using standard File IO.  Under Advanced File Functions, there is a vi called File/Directory Info.  This gives you the last modification date.
If you have a Canon camera, there is a utility that comes with it that is very useful for renaming files by the date the picture was taken.  I suspect there are similar utilities for other cameras.  You also might be able to find a generic utility for free or very cheap.  If you don't have to do it in LabVIEW, there are several other options.
Bruce
Bruce Ammons
Ammons Engineering
Message 4 of 9
(78,629 Views)
Accepted by topic author jeremy_levy
Hi
There are activex exif in the net. I plan to test this one: exif activex.
It looks interestig to extract info from pictures.
Cheers
ALipio
"Qod natura non dat, Salmantica non praestat"
Message 5 of 9
(78,599 Views)
Thanks, I am pretty sure this will work!
Jeremy
Message 6 of 9
(78,596 Views)
Hi
there is another choice (freeware and source code available):  jhead in this kink
It is an exe and  runs fine.
Cheers
Alipio
Message 7 of 9
(78,547 Views)
yes contact me
Message 8 of 9
(45,640 Views)
 How can I contact you privately?
Message 9 of 9
(43,609 Views)
