Machine Vision
Error using Vision Functions
I'm using Labview to capture a image and try to use some functions to recognize a code bar or a number. I installed the Vision for USB and don't have problems to get a image with snap and grab and show this image on screen with the IMAQ Windraw.
The error appear when i tried to use any Image Processing or Machine Vision functions. The following message appear:
"Error -1074396080 occurred at IMAQ Distance Invalid Image Type."
Possible Reason(s):
IMAQ Vision: (Hex 0xBFF60450) Invalid Image Type.
I tried to find this error code but i can't.
Thank for help.
(3,738 Views)
Hi I am guessing that your image is colour. You will need to convert to a greyscale image. Use the ExtractColorPlane VI and extract the Intensity plane. Once this is done, your error should go away. make sure that you declare a new image so you can wire a destination to this vi as well. Hope that helps Mike
(3,730 Views)
Yeah, when I used the ExtractColorPlane.Vi the error go away. But I can't work with a color image?
(3,726 Views)
There are very few functions where you need to work with a colour image, and the majority of cameras in the industrial space are greyscale for numerous reasons. Hence most of the functions will only work on a greyscale image.
Mike
(3,724 Views)
ok, thank you for help 😄
(3,721 Views)
