Machine Vision
Error loading "imaq.dll"
I have a project that was build with LabView, Vision Acquisition Software and Vision Development Module, all of them 64bits versions.
Now, I have installed all the software in a notebook and when I want to open a VI that use Imaq.dll, the Operating System shows the error:
Error in initialization routine dynamic link library.
I have searched for these dll in all of the disc and fount that there are two files imaq.dll. One of them is in Windows\SysWOW64 and his size is 1,681KB; the other is in System32 and his size is 2,537KB.
When I installed the Imaq driver, I have the caution to only include support for 64bits.
When uninstall all of the NI Software, both of the imaq.dll files are deleted.
The notebook have:
Intel core I3
Windows 7 Home Basic 64bits
RAM 2GB
Software NI:
Vision Acquisition Software, August 2010, 64bits.
Vision Development Module, 2010 SP1, 64bits.
LabView, 2010 SP1, Ver 10.0.1 (64bits).
Thanks.
(6,689 Views)
Good Morning,
I need to get some information to get into this issue. How did you get the software you're installing on your PC? It was a DVD or downloaded from web?
I believe something happened during the install and corrupt some files.
My suggestion is to try to install the newer Vision drivers. You can find a link to them here.
Give it a try and let me know wheter it works or not.
Best regards!
Felipe Flores
Technical Support Engineer
(6,675 Views)
Hello Felipe,
Thank for answer.
I have downloaded all the software, I didn't try to download again, it could be something to try.
Also I have asked to NI Support and they have answered. They recommended install the latest versions of Imaq drivers and Vision Modules, too. I did that and all worked fine.
But, the problem is, that I want to make executables with some modifications and send them to our client. So, I guess that with the latest versions I will have some problem sending only the executable.
I want to avoid uninstall the application and send a new installer because the risk is higher.
Because all of the above, I will try to download the Vision Acquisition Ago-2010 and post the results.
PD: I don´t know why my name appeared as ldfjdlkj, when I´m Juanjo339.
Thanks and kind regards.
(6,670 Views)
OK Juan, I will wait for your answer!!
About your name, I really don't know what happened. It's probably a bug of the forum, but now I can see your name "Juanjo339" on your last post here!!
Regards
Felipe Flores
(6,660 Views)
Hello Felipe,
Sorry for the delay in answer. I can solve the problem.
After installing the latest version of the drivers, I uninstall them, but this time I didn't uninstall MAX.
After that, I installed the old drivers (Vision Acquisition Software, August 2010, 64bits) and for my surprise it worked !!!!.
I was using MAX 4.7.7f0
Now using MAX 5.0.0f1
Tanks and regards.
(6,623 Views)
I'm so happy to know it!
Any further help you need, please contact us again!
Best regards!
Felipe Flores
(6,606 Views)
