Machine Vision
Error accessing network (Vision builder 2023 and Labview 2023)
I have vision builder 2023 and labview 2023
I have a school assignment, pretty easy
The thing is that in VBAI i get this message with i create a "Set Variable"
I create the variable, publish it in the network, but i keep getting the same mistake "Error Accessing Network"
I already installed and uninstalled everything, from labview to vision, to everything National Instruments related, restarted, updated my drivers, killed my firewall, everything and nothing seems to be working.
In labview i dont see my Vision Builder to select a variable.
I've read that Distributed Manager helped but it does not show anything.
I dont know if im missing a NI driver or toolkit or something
(2,489 Views)
It seems to be that you tried to use local variables instead of network variables and also using datasocket instead.
What you can do:
Try to create simple LabVIEW project which will hold and publish (deploy) Network Vriables:
Block Diagram is simple and straight forward:
For demo purposes I'll read "ReadDBL", multiply by 2 and write to WriteDBL. Also will write Counter.
Also be sure that you haven't disable autodeploy occasionally:
When running (and deployed at first run), in NI DISM you will see something like that:
Now, in VBAI you should map these Variables
then
Now you can add step where you will write (or read) variables, for example, I'll increment ReadDBL:
and now it works:
And if you need to connect control or indicator with data binding, you can do it by this way:
Test project in the attachment. Hope it helps.
Andrey.
(2,429 Views)
