‎10-17-2012 03:06 AM
Hi
I am using an USB Camera for my setup. I always get an error message (-2147418113) when I start-up my PXI system and open the camera session. I see the camera in MAX and its also possible to read out the camera information. But it fails when I try to open the camera session or when I try to grab an image in MAX.
After re-connecting the USB Camera I dont see the error mesage anymore and everything works as expected! Is there a workaround the reinitialize the USB Port or..?
Thanks in advance
‎10-22-2012
10:21 AM
- last edited on
‎08-13-2026
08:44 AM
by
Content Cleaner
I found some information about your error message. Maybe this helps.
Receiving Error -2147418113 "Catastrophic failure in xxx.vi" When Using ActiveX Server:
http://digital.ni.com/public.nsf/allkb/E0FA5D83F1E5276B86256C7E005FD83C?OpenDocument
[broken link removed; article no longer available]
‎10-26-2012 08:37 AM
Hi Suse
thanks for your answer. I will check each link to see if there is a solution to my problem. I will keep you informed.
‎10-29-2012 03:48 AM
Suse
I have updated all USB camera drivers, which solved my problem at the end! 🙂
Thanks!
