Hi Nitrof,
This appears to be a Microsoft error code that often results when activeX objects are not registered properly. Are you using activex? What software are you trying to interface with? (Excel? Internet Explorer? etc?). Is the version of this software on your development computer the same as the version on your deployment computer?
This doesn't appear to be a LabVIEW issue. Are you able to call this object succesfully in other programming environments (VB, .NET, etc)? If so, you may want to consider contacting whomever developed that software.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
