Machine Vision
Error 1172 occurred at Invoke Node Error calling method
hello i am having this problem when i try to stop vi after running it (kintesia) ," Error 1172 occurred at Invoke Node Error calling method "
knowing that i am using labview 2015 & labview 2014  i am using kinect for windows (installed Microsoft kinect v1.8 + VAS +Vision module +kintesia)
(4,419 Views)
Hi Dolaios7,
It looks like you're using an additional library to interface the Kinect with LabVIEW. Is it the one from MakerHub? If so, it might be useful to post this on their forum. If it's not that one, which API are you using? Or are you making your own?
In general, it looks like the error message is pretty helpful. Have you seached the Microsoft Dev Network for the exception code? Since Microsoft makes the device, it's very possible they have more information about Microsoft.Kinect.ColorImageStream.Disable.
Kind Regards,
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(4,379 Views)
