05-19-2009 11:40 AM
Hello all,
I have written a VI in labview 8.2 to detect motion for the use in speckle interferometer. I am using PCI1411 frame grabber and PULNIX2013 MODEL CAMERA. At the moment everything is working fine but when i try to save image to a filei get error code with number Error-1074395997. Could somebody help me in this regard? THanks in advance.
visu
05-19-2009 03:10 PM - edited 05-19-2009 03:13 PM
visu
Sounds like an invalid file path. Put a probe or indicator on the file path wire and see if it is correct.
It also looks like you have a floating T/F constant Save control over your case statement frame.
-AK2DM
