Machine Vision
Error -1074360271 occurred at IMAQdx Start Acquisition
Dear all,
I am using a Hitachi HV-F202 camera (GigEVision CCD) and I try to run it in labview. I conntected my camera via a docking station and ethernet cable. However, I cannot start my labview code and I always get the following error message:
Error -1074360271 occurred at IMAQdx Start Acquisition.vi
Possible reason(s):
The system cannot acquire images. The packet size may be too large for the network setup or a firewall may be blocking the network traffic from the camera. For more information, visit ni.com/info and enter 'GigEVisionNetworkConnectivity'
I have turned off the firewall but it still isn't working.
Do you have any tips?
Thank you!
(2,945 Views)
Accepted by topic author Malou0207
Please check, all You network components support jumbo frames. Activate whis feature in ethernet adapter settings. Other way is to reduce the size of packages in NI MAX below 1500, but if possible use jumbos.
I hope it helps!
(2,943 Views)
