Machine Vision
Error 1003 in Vision Builder during code creation
When I select "Migrate Inspection to Labview" in Vision Builder 2.6.1, I get the message "Error 1003 occurred at Invoke Node in IVB Call LabVIEW VI Creation.vi   Possible reason(s): LabVIEW:  The VI is not executable." This happens regardless of the project, I've tried migrating my own projects and also the example projects. Any ideas? This problem was not present with the initial installation, something change but I can't figure out what.
(2,997 Views)
Hello rylog812,
It sounds like something might have corrupted itself in either Vision Builder for Automated Inspection (VBAI) or LabVIEW.  Try repairing the installation for both VBAI and LabVIEW and see if the problem still manifests itself.  You can repair the software by going to Add/Remove Programs in the Control Panel.  Select National Instruments Software, and click change.  A list of all National Instruments software will appear on your machine.  Select Vision Builder and click Repair.  Do the same for LabVIEW.  If you are unsuccessful with the repairs, try reinstalling these products.
Mike Torba
(2,975 Views)
