Machine Vision
Error 0xbff60057
Hi all,
I'm currently trying to set up an old PIV system. There are some issues related to the FrameGrabber: NI PCIe-1427.
When I try to take a picture using the MAX application I get the Error 0xbff60057.
I haven't found anything useful regarding this error so far. Did anyone of you face a similar problem?
Any hints on the issue are yery welcome 🙂
Thanks!
(1,620 Views)
I used LabVIEW Explain error and this is what it returned, hope it gives you a hint. I have never faced such an error before.
-AK2DM
(1,586 Views)
Thank you for the info on the error - I guess this is related to an issue with the camera properties.
MAX recognizes ist as 2048x1024 px while it has 2048x2048.
(1,571 Views)
I was thinking more along how the physical data lines are used versus what MAX is configured for.
What is the make/model of the camera? You may need to create a custom *.icd file for it.
Here are some addition resources to start out with, and have you read the documentation for the 1427?
https://www.ni.com/en-us/support/documentation/supplemental/19/camera-link-getting-started-guide.htm...
-AK2DM
(1,560 Views)
