Machine Vision
Error 0xBFF60492 on IMAQ USB snap.vi RT Video not support displaying selected color depth
Attempting to snap a picture with NI-IMAQ for USB in LabVIEW 8.0  using the following procedure.
1)I get the first enumerated camera, 2) open a session, with returned string [0], 3) start a session, 4) snap a picture and 5) close vi.  My problem is that in step 4 with the IMAQ USB Snap.vi, I get the following error.
Error -1074396014 occurred at IMAQ USB snap.vi
The image passed is not valid.
Possible Reasons(s):
IMAQ Vision: (Hex 0xBFF60492) RT Video Out does not support displaying the supplied image type at the selected color depth.
I give the snap.vi an Image in from rightclick->Create->Control or rightclick->Create->Constant.  The output image (on the Front Panel) created by rightclick->Create->Indicator.
LabVIEW should insert the correct data structure to match the expected input/output, and there is nothing I can that changes he color depth.  The GetImageInfo.vi reports that the camera is set up for 4 Bytes Per Pixel, with the rectangle 352x288.
Also the error message refers to RT Video Out, but I am using USB.  This distinction is significant in NI Vision Assistant.
(4,018 Views)
OK, I wrote this error up too quickly.  The manual says to use the IMAQ Create to initialize the image structure.
Sorry for the extraneous posting.
(4,015 Views)
Hi
Where did you find this "IMAQ Create" vi?
I can't find it in the pallette.
Regards Bjarne
(3,576 Views)
Found it here:
(3,558 Views)
Hello together,
I wanted to use a Sanyo Xacti CG 10 video camara in LabView.
By using the NI-IMAQ for USB Snap I get the following error: IMAQ Vision: (Hex 0xBFF60492) Ungültige Blit-Funktion des Videoausgangs.
Is it possible, that I can not use this camera in LabView?
Thanks a lot for your reply
(3,525 Views)
