09-02-2010 07:01 PM
I am using a JAI camera, then I want to captured a few images, so i select Finite Acquisition With Post Processing with 5 or more images to capture,
When i start to test it, it always shows
Error 10743971500l
NI. IMAQ: A timeout error occured while waiting for the specified event.
If waiting for an image, verify that all video data is acquired withing the time period.
If waiting for a signal, verify that the signal assertion occurs within the timeout period
How to solve this problem?
Thank YOU
09-02-2010 07:03 PM
09-02-2010 10:05 PM
I think it might be because of the initialization problem with the camera... But am not sure coz i have not used the JAI CCD cameras... check the initialization by setting break point...
There may be always some good solution left unposted
09-03-2010 12:37 AM
Single capture is working well.
Only if I want to capture more than one image.
09-03-2010 01:05 AM
can you post the BD you made..
09-03-2010 01:23 AM
the same error notification as i posted earlier 😃
09-05-2010 09:31 PM
here is the BD
09-07-2010 06:05 PM
I am still having the same problem.
I couldnt get rid of the timeout error =(
Any solution guys?
09-09-2010 06:28 PM
I was told that the problem is most probably because of the resolution of the image is too big.
04-16-2024 05:25 AM
I used the IMAQ SetImageSize element and resized the IMAQ and the error was solved.
