05-13-2009 08:25 AM
Hi guys
Let's consider the situation I am drawing a ROI interactively, e.g. in VBAI, IMAQ ConstructROI window or in an image control. I know I can use the Ctrl key to combine (add) multiple ROI contours, generally of different types. Now is it somehow possible to specify an internal contour, i.e. a hole? I know I can do it programmatically, but can I do it interactively?
Vladimir
Solved! Go to Solution.
05-13-2009 09:57 AM
ROIs don't really have an interior/exterior option. You would have to do it programatically.
The only feature I can think of that might help is an annulus, since that has a hole in the center that you would consider interior.
Bruce
05-13-2009 10:08 AM
Vladimir -
Just to confirm, there's no way to draw internal ROI contours interactively. If this is something you would find useful, you can submit a product suggestion request at the Product Suggestion Center.
Greg Stoll
Vision R&D
05-13-2009 01:44 PM
05-13-2009 02:01 PM
Randall -
Just as an FYI, this was reported as CAR #157205 and we are hoping to be able to fix it in the next version.
Greg Stoll
Vision R&D
05-15-2009 02:33 PM
05-15-2009 02:50 PM
05-15-2009 03:12 PM
Randall -
Do you mean like getting the index through a property node?
That's an interesting idea - I'd recommend submitting a suggestion for that.
Greg Stoll
Vision R&D
05-18-2009 10:32 AM
