Machine Vision
Does NIVision OpenCV Utilitis Module support Win10 32bit?
Recently, I have encountered a problem with the NIVision OpenCV Utilities Module,
I need create a program to check the ambiguity of camera picture stream,however,I cannot find this function in NIVision Developpement Module, therefore, I need use NIVision OpenCV Module to create this program to realize this function, which you can find attached.
"Check Program1": Use DLL to check the ambiguity of picture "Sample Picture"
"dllmain.cpp": OpenCV Program   "Sample_Picture": the sample picture for test
I used Visual Studio compile this program to DLL in X64 and X86, however, I found that this VI worked in Win7 32bits and 64bits, Win10 64bits, however, Win10 32bits doesn't work.
After I checked the info of NIVision OpenCV Utilities Module, it has following message:Compatible OS Versions: 8,7,Vista.Maybe this is the possible reason.
Do you have any idea how to solve this problem? As the customer computer is Win10, I need use this module with Nivision to check the ambiguity of camera timely.
Message 1 of 1
(3,504 Views)
