Machine Vision
Display Multiple Camera Views Through VGA Port on Compact Vision System
I am trying to display 3 firewire camera images through the VGA port on a Compact Vision System (1450). Just plugging in cameras and connecting the VGA cable, I can only get one camera view, and as far as I know there is no way to switch between them.
As I understand it, I can write a LabVIEW program to run on the CVS, that outputs whatever I want to the VGA port. Any advice on how to display video feeds from all 3 camera inputs to the VGA port, sort of like a security camera monitor? Thank you!
Brandon
(3,683 Views)
I have figured out how to do this by building my own VI. I don't know if there is a built-in way to do it, but it can be done effectively with a VI that combines the images together. If anyone ever needs any help/code just let me know.
Brandon
(3,668 Views)
Hey Brandon,
Its good to see you would able to build a LabVIEW VI to accomplish the task at hand. Sounds like the code you build would be useful for other in a similar situation. If your up for it, you should create a ni.com/community page with your code. This particular routine would be a welcomed addition.
In terms of a build-in way to do this, unfortunately, there is not a built-in way to stream all three cameras to the VGA port. Might be a worth while product suggestion though.
Hope this helps.
-Ben
WaterlooLabs
(3,660 Views)
For anyone concerned, I have uploaded the code I used to the ni.com/community website. It can be found here.
(3,619 Views)
