Machine Vision
Detect wrinkles on PCA board
I'm new in Labview and i'm planning to detect wrinkles on a square by using VDM.
May i get some advice how to do it?
Thanks. 🙂
(4,984 Views)
Not knowing anything about your project makes it difficult to help.
I would probably use side lighting, probably a ring light designed for dark field illumination.  The light won't show up much on a smooth surface, but should highlight any bumps or wrinkles.
Bruce
Bruce Ammons
Ammons Engineering
(4,966 Views)
-Please provide some images, that might give better idea.
-In general texture segmentation can be good start to detect wrikles, dents etc.
Refer: http://www.ni.com/white-paper/12325/en/
-Same examples are provided in LabVIEW also.
uday
(4,960 Views)
Thanks for the suggestion.
Trying with the tutorial.
(4,900 Views)
