Machine Vision
Define Input Array formula node
is possible to put a array in a formula node?
For example you have 20 points found with the Find Edges tool,
I want not put every single point into the formula node.
I work with NI Vision Builder Version 2010
Thank you
(3,518 Views)
No, VBAI is right now not capable of handling arrays in the calculator step.
However you can access them either directly if it is a measurement from another step and you can call the calculator step iteratively or you use the index measurements step.
Christian
(3,509 Views)
