Machine Vision
Create camera file for Dalsa PT22-04M30 Color Camera and PCIe-1433
I have the Dalsa PT22-04M30 Color Camera and an NI PCIe-1433 Camera Link Frame Grabber Card.
I tried using the Dalsa PT21-04M60 (60fps and monochrome as compared to 30fps and color) as the baseline for creating a new config file but the NI Camera Generator utility shows the PCIe-1433 as not supported (grayed out).
Why is this and how do I change configuration to support color as opposed to monochrome?
Any help is greatly appreciated.
Randy
(3,748 Views)
Wich version of Camera File Generator do you have?
You can find the last version here: ftp://ftp.ni.com/support/imaq/pc/ni-imaq/cfgenerator/
Then to change you icd file to color mode, go to Settings->Camera, you should see this window below
Then choose 24bit instead of 8bit.
Regards
(3,746 Views)
I had downloaded the latest version of the Camera Generator before starting.
I started with the Dalsa PT-41-04M60 ICD file, and the option to select 24-bits is grayed out. I can get to it if I start a new file but 99% of the information is the same.
Why is it grayed out? How do I get that field to accept a change?
Thanks for the help 🙂
Randy
(3,732 Views)
If that camera delivers a bayer image to the framegrabber (my guess) rather than an already-decoded color image, you do not want to change the format in the camera file to 24-bit color. You would keep it set for the right bit-depth of grayscale and then use the bayer color decode examples shipped with IMAQ.
Eric
(3,730 Views)
I can change the bits per pixel to 24 but that was not the solution since the camera has no on-board decoding.
I can capture images using the PCIe-1433 card but when I convert them in LabVIEW using Bayer LUT (GBGB::RGRG) the colors are muted and do not show the definition.
Does anyone have an ICD file for the Dalsa PT-22-04M30 camera or any suggestions on how to properly convert the received images to color?
I have started with the NI example "Snap with Bayer Decoding.vi"
Randy
(3,727 Views)
