Machine Vision
Counting trigger pulses during saving image
Could you help me? I want to ask how I can count trigger pulses during saving images. First I am using NI-1429 and Basler Sprint spL4096-140k. I have an encoder with 56k resolution with about 18k pulses per second; shutter is set to 36 microseconds.
I want to save an image with resolution 56k x 4096, which is one revolution of a container, then I want to wait 12 revolutions (during this time captured data must be saved and some pre-processing have to be done).
How can I count the trigger pulses, during this data operations (saving this image takes some time) and then how can I trigger acquisition of next image? I can imagine 2 parallel while loops. In first one, there is capturing and then saving with processing and in second one your function to read trigger status. But I do not know if this while loop is started so often Ii need to and what about communication between each other while loop?
Thanks for reply
Dan
(3,126 Views)
Dear Dan,
From your description I understood that you want to use line-scanning with IMAQ in LabVIEW.
When using triggers, you need to configure the triggerlines and the actions for the triggers.
I found in the LabVIEW help a VI, which is responsable to set up the triggers for line-scanner. This VI has an input, where you can describe how many trigger impulses you can skip at the end of the line.
I attached a screenshot of my LabVIEW Vision help:
You can reach this VI in the Block diagram function palette on this path: Vision and Motion > NI-IMAQ > Signal I/O > IMAQ Configure Trigger3.vi
Using these settings you don't need to use an other while loop to check the trigger state, which I think is not a good practise, since you get 18k trigger pulses per second.
If you need to count the pulses with a custom way, and this solution isn't good for you, you can consider using DAQ device with counter inputs.
Best Regards,
Tamas Szekely
(3,109 Views)
