Machine Vision
Corrupted VBAI inspection File
Hi All,
I am hoping someone can help. I saved an inspection routine that had a couple of settings tweaked and rebooted the IPC once everything had closed.
Upon trying to open the the project it keeps coming up with "The file selected is not a valid inspection".
If I try to open the project from the AI2020 menu it opens a 6 month old version of the project, which was basically nothing apart from the first steps in what has been a long development project.
a) is there a way to recover what appears to be a corrupted inspection?
b) does VBAI have a backup file of edited inspections?
I am trying to avoid having to rebuild the inspection as it will take a couple of weeks to redo and calibrate to the equipment in question.
Ken
Message 1 of 1
(1,117 Views)
