Machine Vision
Converting byte[,] to NI PixelValue2D object in C# visual studio?
I am currently using an old code which carries out online image processing using the NI libraries. I currently use a different frame grabber board and would like to still use the NI based processing loop for my acquisition software.
Is there a way to convert my 2D byte arrays into the pixelValue2D objects? Any suggestion/comment would be appreciated.
I'm currently programming the software on C# on visual studio 2017.
Thank you.
Message 1 of 1
(2,571 Views)
