Machine Vision
Control Motor Via Motion Detection
Dear sir,
One more thing please send the VI working with vision assistant secondly the files are not compatible to 12.0 (there is error coming during opening of VI).
With regards,
Gagandeep sharma
Message 11 of 18
(2,135 Views)
Strange about the error, it looks ok if i open it.
I am attaching the vi's saved for LV2010.
I do not use vision assistant, but it is really straightforward to do geometric matching. Load the rgb image, extract intensity plane and do geometric matching (train the template, and be careful to consider all the scales when you are adjusting the settings). Then just generate the labview code.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 12 of 18
(2,128 Views)
Dear sir,
Got it and will reply soon.
Gagandeep sharma
Message 13 of 18
(2,124 Views)
Thank You for your response
I solved my Problem
But I have another question :
When I searched in web, I found this equation :
d = (FL * RHO * IH)/(OH*SH)
Where:
d = distance to object (mm)
FL = focal length (mm)
RHO = real height of the object (mm)
IH = image height (pixels)
OH = object height (pixels)
SH = sensor height (mm)
but I don't know how to find focal length and sensor height to determine distance
Can you help me ?
Message 14 of 18
(2,120 Views)
Just treat the equation as a bunch of unknowns that can be combined into a single constant, which is divided by OH.  You get:
d = C / OH
This is really easy to calibrate.  Measure a few distances and the object height in pixels.  Multiply each pair together to get an approximate value for C.  Average all these values to get a good value for C.
If you don't like this method, focal length is usually printed on your lens (something like 16 mm), and sensor height is the physical dimension of your sensor.  You can calculate it by multiplying the vertical number of pixels in the image and the physical pixel sensor size (something like 5 um), which would be in your camera manual.
Bruce
Bruce Ammons
Ammons Engineering
Message 15 of 18
(2,116 Views)
Hello
I am sorry, I'll tire you but I can't know until now  how to get the focal length and  physical pixel sensor size
I'm using HD Webcam of my laptop
Message 16 of 18
(2,110 Views)
Hello
Message 17 of 18
(2,110 Views)
Since you can't get these measurements, the only way is to do the calibration I talked about.  Measure the object height (pixels) at a bunch of different distances (mm) and fit a 1/x curve to the data.
Bruce
Bruce Ammons
Ammons Engineering
Message 18 of 18
(2,108 Views)
