Machine Vision
Connection to the RT target has been lost
All,
  I need somone help to resolve the following error message:
  "Waiting Connection to the RT target(CVS1450) has been lost"
This error message display when I ran the attached program. I'd put in a break-point and walk through the code but it's not obvious when the error message pop up.
I have CVS-1456 and Prosilica camera connected to the USB port-A. Then intend of the attached program is to acquire an image from the attached camera, share the image acroos the network and locate a light pattern.
(3,789 Views)
I'd like to add more inforamtion to my previous posting as follows:
Some how I can't re-deploy the code to the CVS-1456 after the system crash. I can ping the CVS with good respond, ftp to the CVS without any issues and IMAX still see the CVS. I tried to re-boot the CVS-1456 may times without any success to re-deploy the code from the project explore.
SC1
(3,784 Views)
Please ignor this posting because Vivek from NI is helping me over the phone.Smiley Very Happy
(3,762 Views)
Now I can re-deploy any code to the CSV-1456, thanks to Vivek from NI support. Just wants to put a note in here just in case some else has the same issue. To work around this issue, Vivek recommended me to reformat the CVS-1456 and re-install all necessary software and drivers to the CVS. This also fixed flashing LED status(flashing 4 times). Make sure you make a backup of you CSV-1456 setup after every is working again, I've learned my lesson the hard waySmiley Mad. But I still don't why my code crashing the CSV-1456 from the beginning
Thanks a million to Vivek for walking me through the CVS-1456 setup.
SC1
(3,742 Views)
