Hi akang,
Using NI-IMAQ, you can save video into the AVI format. In LabVIEW, these VIs can be found by going to your functions palette, and selecting:
Vision and Motion»Vision Utilities»Files»AVI. On this palette, you can find all of the AVI VIs that are included with the NI-IMAQ driver. These VIs allow you to select which codec you used to compress the images, but you can only create AVI files. There is a really good example program which can be found by going to
Help»Find Examples... and then selecting
Hardware Input and Output»IMAQ»File Input and Output»Grab and Save to AVI.vi.
Wes Pierce
Principal Engineer
Pierce Controls
