Machine Vision
Color Spectrum in examples
In the ColorMatching Example, http://zone.ni.com/devzone/cda/epd/p/id/5549, it states that the the "VI uses another example to learn the color spectrums".  I am assuming that this other example is the ColorLearn Example, http://zone.ni.com/devzone/cda/epd/p/id/5550.
However, the ColorLearn Example returns either a 16x16, 30x30, or 58x58 array depending on color sensitity while the ColorMatching Example uses a 4x30 array for the spectrum.
How do I connect the two together?
(3,927 Views)
Accepted by topic author chinghwayu
Figured it out ... the output of IMAQ ColorLearn is a 1D array that describes the color spectrum.  The reason for the 2D array is to display the histogram.
(3,923 Views)
