Machine Vision
Color LED Image Acquisition problem
Hi all,
I'm trying to recognize LED's Color in a PCI, but the LED are saturated. I Tryed to ajust the focus and Iris, but the Image still saturated. I'm using a 1408 in still color mode and EVI 371 sony camera block. The color led are red, yellow, blue, green and to ambar.
Thanks for all
ALceu
Alceu Rosa Neto
RA Eletro Sistemas LTDA
(3,248 Views)
When you say the image is saturated, do you mean that there isn't enough variation in color to tell the difference between the colors you mentioned (i.e. they are washed out)? If so, it sounds like it might be a problem with the lens or the environment, in which case some sort of filter may help.
(3,229 Views)
