Machine Vision
Color Fuse Inspection
Dear MAHARLILA,
I have same type of Requirement of fuse box inspection.
Please suggest and share some tips or Example to create good application for Fuse inspection.
Please find Fuse box image for your Reference.
Regards
Sachin Soni
Message 11 of 14
(1,579 Views)
This inspection is discussed in the Imaq Vision For LabView manual, and at one time there was example code.
https://www.ni.com/pdf/manuals/322917a
Fuses are an excellent example of Design for inspection.. Each current rating has a different color, so OCR is not required.
In the image posted in this message, Field of View and lighting needs to be optimized.. One of the fuses has critical glare that obscures the color and value of the fuse.
Check out the Color Threshold example.
Bug me if you need more help.
Message 12 of 14
(1,572 Views)
Dear sir,
Thanks a lot for tips.
i will try this. and share Update ASAP.
Regards
Sachin Soni
Message 13 of 14
(1,565 Views)
Check out the Color Threshold example.,
Checked but Unable to detect of ROI
Message 14 of 14
(1,539 Views)
