Machine Vision
CoaXPress
Does NI software support the CoaXPress framegrabbers? I'm thinking about these Basler cameras:
https://www.baslerweb.com/en/products/cameras/area-scan-cameras/boost/
CoaXPress 2 uses GenTL, which is a module of GenICam providing a unified mechanism for grabbing and streaming images from the camera.  So perhaps IMAQdx already has support?
(6,952 Views)
Accepted by topic author D*
Hi D*,
We do not currently support third party CXP frame grabbers from our driver. Some frame grabber manufacturers have created their own LabVIEW wrappers. If you'd like to get more insight on our CXP plans you can direct message and we can set up an email or call to get you more details.
Have a great day!
Matt G.
Product Manager
(6,908 Views)
Another possibility to consider is the 10GigE cameras.  I am told they work just like GigE cameras, just 10x faster.  You have to buy a 10G ethernet interface board, but MAX can't even tell the difference.  I haven't had a chance to verify it yet, but we are looking at an SVS camera for a project.
Bruce
Bruce Ammons
Ammons Engineering
(6,900 Views)
Yes indeed, 10GigE (or we should say 10GigE Vision) cameras are handled through IMAQdx the same way as any other GigE Vision camera.
However, 10GigE interface although it is fast is still far beyond the maximum capabilities of Coaxpress. But of course, it depends on what the camera is requiring.
And by the way Bruce, SVS Vistek cameras are a very good choice ! (ok, this is a SVS distributor speaking 😉, but I truly mean it !).
Sami Fathallah
Technical Manager
Opto France
(6,879 Views)
I'm always happy to see we are not the only ones requesting Coaxpress ! 😊
The coming of next generation Sony sensors as well as GPixel ones for instance should definitely establish Coaxpress as the most available interface and make CameraLink obsolete.
Sami
(6,876 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DnN0CAK&l=en-US  we can help you here with our Claxon line of CXP-12 frame grabbers.  We also have a Claxon CXP1 specifically for use with single link CXP12 cameras.   And you can actually see the camera in action here
(6,771 Views)
I also like to see products like 1477/1483 with a camera interface to FPGA, we can do much more than just grab the picture and do some offline analysis.
(6,089 Views)
