Machine Vision
Chip Detection Algorithm
i would like to inspect surfaces and find anomalies. Pattern matching doesn't work well. Which tool would you suggest to use?
I attached original images and ones with a filter i would use labeld with "good" and "bad".
Thanks for your ideas
Sincerely
(2,179 Views)
From the set of images, it appears that the images that pass are (more or less) symmetric about the center of the disk.  One approach would be to unwrap the image  (Imaq unwrap) and then run a sliding average across the resulting image, comparing adjacent windows looking for changes above a preset threshold.  It's a guess.. Nothing is ever that easy.. 🙂
(2,139 Views)
I was working on semiconductors to detect all kind of issues like that.
I usually had good success with texture analysis.
LabVIEW has good set of VIs for texture analysis with very little documentation.
 https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/texture_pal.html
I strongly recommend to read some theory on the subject. But start with NI documentation.
I was using texture analysis to extract features.
Then train classifier to detect the bad images.
All the best - Amit
Amit Shachaf
(2,132 Views)
