Machine Vision
Check Focus Of An Image With Standard LABVIEW Functions
Got it bruce, thanks for the help!
Message 11 of 14
(4,337 Views)
Hi Jimmy01,
The advice BruceAmmons is giving is spot on.  But to answer your question from above, you will not be able to use the IMAQ functions in an executable that you distribute to clients without purchasing a vision run-time engine license.  This is separate from the LabVIEW run-time engine.  Just to reiterate, although the IMAQ drivers are free, putting them in an executable will require purchasing that license.  The price of this license is listed here as $423: https://www.ni.com/en-us/shop/product/vision-development-module.html?partNumber=778044-35
If this disqualifies use of the IMAQ drivers, it seems like the advice still holds true, but you will need to find a way to convert the image to an array yourself since you won't be able to use the IMAQ Image to Array function in your executable.
Julian R.
Message 12 of 14
(4,332 Views)
Actually, I am pretty sure you can use IMAQ ImageToArray without an IMAQ license.  It is part of the base package.
Another note is that the Vision Run-time license includes the Vision Acquisition license, but not the other way around.
Bruce
Bruce Ammons
Ammons Engineering
Message 13 of 14
(4,329 Views)
Nicely done.
Message 14 of 14
(3,708 Views)
