Machine Vision
Changing from an 8-bit input to 16-bit input, vi stops working
My vi works perfect in 8-bit (mono mode) with my CCD camera, but when I change the input to 16-bit through M&A the vi stops working or stops after the first frame. Is it a problem with vi, IMAQdx or do I need to change something else in M&A? I'll appreciate any ideas on where to begin to debug the issue....
Thank you,
(3,919 Views)
In image type have you defined 16 bit?
18261i0E48FA89528C5C97
(3,918 Views)
no, but it'll be the next thing I'll try. Thank you.
(3,916 Views)
I've tried your suggestion, but it still doesnt work. What's the next thing to check?
(3,901 Views)
Could you provide a little bit more information about the error that you are receiving?
Marti C
NI Medical
(3,891 Views)
I'll be happy to, but it's not an "official" error. The vi receives the first frame/image, and then nothing happens. There is no failure per se. As I mentioned above the vi works fine in the 8-bit mode. I'll be happy to provide more information, if you'll give me specific things to look for.
(3,889 Views)
Can you post your vi? Or a screen shot?
(3,868 Views)
