Machine Vision
Case Structure Function in Vision Builder
I am quite new in working on VI Block diagram of Automated Inspection functions.
I developed a very basic program and could not locate "case structure" function option in VI Block diagram.
(3,691 Views)
Did you try to right-click on block diagram, go into "structure" palette and find "case structure"?
(3,633 Views)
Dear Member,
Thank you for your Input.
When I click right-click on block diagram, I am not able to see "Structure" palette.(Attaching Screenshot)
Also, In order to search "case Structure", On clicking search option nothing appears.
Please suggest.
(3,524 Views)
Dear Team,
can anyone suggest their input in this regard.
N
(3,460 Views)
Accepted by topic author JN_23
I confirm that the case structure does not exist in the VBAI calculator step (I'm still using VBAI2018 but I guess there is no change in more recent versions).
As a workaround I use, a chain of "Select" primitive : quite boring and frustating but it works.
However, another better alternative is to use the formula node (in the numeric palette) : I just tried it and it does the job.
Sami Fathallah
ALLIANCE VISION
HW and SW Components for Scientific Imaging and Machine Vision
http://www.alliancevision.com
(3,453 Views)
Thank you Sami Fathallah for the response.
(3,422 Views)
