09-08-2006 05:43 AM
09-08-2006 06:31 PM
Hi All,
Just to let you know the solution to the problem is to make sure that the image size and frame rate selected from the 1st camera is small enough to leave some room on the bus for data from the 2nd camera. With 8 bit 640x480 images, the max frame rate to support 2 (3 according to documentation but I have not tried this) is 30 fps.
Hope this helps someone else!!
cheers,
Peter
09-15-2006 04:19 PM
09-22-2006 10:49 AM
Johann-
Does the packet size determine the fps of the camera or is there a fps setting somewhere I am not aware of?
Steve Mleczewski
Industrial Logic
09-22-2006 10:55 AM
Steve
The packet size does determine the frame rate.
Johann
09-23-2006 10:25 PM
04-27-2007 08:42 AM
Hello johannS,
I want to know please how did you come with those calculations that you made concerning the bandwidth
Typical bandwidth (bytes per packet) numbers:
640 x 480 x 8-bit mono @ 30 fps: 1280 bytes
640 x 480 x 8-bit mono @ 60 fps: 2560 bytes
640 x 480 x 24-bit color @ 15 fps: 3840 bytes
Thank you
Tchaou
04-30-2007 10:48 AM
