Machine Vision
Can I use notifiers to synchronously start IMAQ Start and DAQ start VIs ?
I know there are hardware solutions (RTSI based and trigger based) to synchronize starting image and analog acquisition.
For reasons, I cannot use hardware solution. So now I would like to find software solution to start the two acquisitions simulnateously.
And rely on the fact that both camera+framegrabber (PCIe1433) and DAQ cards (PCI 6251) has microsecond (better) accuracy.
So if I can start the two acquisitions simulnaneously, I can assume that with millisecond accuracy (limited by windows OS) I will have the images (100Hz) and DAQ signal (50kHz) synchronized till the end of acquistion.
(A) Am I right ?
(B) Now the part 2 of my question is whats the best method to software-trigger the two acquisitions ?
1. Use the Merge Error Vi and send error wire to both Start (IMAQ and DAQ) VIs.
2. Use Notifiers. Here I generate a notifier and wire "wait on notification" to both Start VIs ?
Which is better ?
(C) Is there a better way than this ?
Any and all help appreciated.
thanks
gvstemp
PS: Only reason I am posting in 2 forum sections is to get wider audience.
Thanks.
(2,786 Views)
Hi gvstemp,
For those who are interested, this question was addressed on gvstemp's other post
Good luck and let us know if you have any more questions!
Matt
NI Community Team
(2,763 Views)
