Machine Vision
Can I use ISC-1782 smart camera like a local GigE/USB camera?
My ISC-1782 smart camera (NI Linux Real-Time version) is working well by deploying an example NI-IMAQdx image acquisition VI (Grab (178x Smart Camera)) to the camera as a remote system. But I want to use this camera with many other LabVIEW functions that cannot be deployed to the camera (e.g., play a sound file). Is there any way I can use this smart camera as a local GigE or USB camera connected to a laptop without deploying any VI to the camera? I tried using NI-IMAQdx Open Camera directly in LabVIEW but cannot find and connect the camera.
Please advise how to solve this problem. Thanks!
(2,968 Views)
I don't think that is possible, but I'd be happy to be corrected by NI.
Try it with "Vision Acquisition Express" .. just to be safe
Two possible solutions
- some sort of handmade stream
I would probably deploy a minimal acquisition with a shared image variable in VBAI: http://www.ni.com/tutorial/12322/en/  and then just read that variable... plus maybe a counter (so I can see that there is a new pic)
Other links that could be interesting.
https://forums.ni.com/t5/Example-Code/Streaming-Images-from-a-Compact-Vision-System-to-a-Local-AVI/t...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7kbSAC&l=en-US
- or you could try  "faking" a GigE camera by implementing parts of that TCPIP based protocol by hand. It's comparably easy to fool NI MAX/IMAQdx into thinking they are talking to a GigE camera.
(2,920 Views)
Thanks a lot for your reply on two possible solutions. I will try VBAI method to see if it is working. I am also interested in your "faking" GigE camera method. Could you please provide some details on how to "implement parts of that TCP/IP based protocol by hand? Should I use "IMAQdx Discover Ethernet Cameras" VI first to find the smart camera?
Thanks a lot!
(2,909 Views)
