Machine Vision
Can I install a PCI-GPIB and PCI-1405 IMAQ board in the same system?
I had a PCI-1405 IMAQ board working well in a Dell GX270 desktop PC.  I installed a PCI-GPIB and the PCI-1405 disappeared (MAX could not find it, nor could my app).  The PCI-GPIB worked fine.  I removed the PCI-GPIB and the PCI-1405 came back.  Is it possible to get these two working together?  I have not tried a USB-GPIB.  Would that work?  I'd rather not spend the $$ to find out it wont.  Thanks.
Dave Duperon
(3,731 Views)
Have you tried swapping PCI slots to see if the order has anything to do with the behavior you are experiencing?
Also, what is your power supply rated at, as in how much power is getting to the PCI slots?
Chris Van Horn
(3,716 Views)
I have not tried anything.  I just wanted to make sure the two are SUPPOSED to be compatible.  I will try swapping their locations and check the power supply.  Thanks.
Dave Duperon
(3,707 Views)
And another quick question. Is this one of OUR GPIB boards, or is it third-party?
Chris Van Horn
(3,696 Views)
Yes, it is a National model number PCI-GPIB.
Dave D.
(3,691 Views)
