Pat,
I think it can be done. I have a couple of suggestions.
Can you improve your lighting? That always makes it easier to do the analysis. You can experiment with a few techniques to get better definition of the larger dent.
I used "Find Straight Line" with very low parameter values (contrast = 8, filter width and steepness = 2) and it did a pretty good job of finding the edges of the larger dent, even with the bad lighting.
There are a few other issues, such as locating the dent, that would still need to be addressed. I don't know if it would always be in the center or if you would have to search for it.
Hopefully this will get you started.
Bruce
Bruce Ammons
Ammons Engineering
