Machine Vision
Camera attributes are different when VBAI script is called from LabView than when run in VBAI.
Script runs normally and is stable in VBAI 3.5.  When called from LabView 8.6 app, image is significantly different.
Problem comes and goes.
Firewire camera.
(3,510 Views)
Hi Dan,
Could you please give us some more information about your problem?  Are you acquiring in LV, or trying to call the VBAI script from LabVIEW?  And what is different about the image--frame rate, color, size?  How does the acquisition look in MAX?  Are you doing a Snap or a Grab?  Have you tried running one of our shipping examples (Help>Find Examples>Hardware Input and Output>IMAQdx)?
Marti C
NI Medical
(3,485 Views)
