Machine Vision
Calibration camera starting
Hi, I'm starting in vision module, someone could tell me if it is possible to make calibration camera without vision assitant and how? please
(2,793 Views)
Hi!
Why don't you want to use Vision Assistant?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QsaSAE&l=en-US
The other way I think, maybe will be using an example as Grab.vi, and make changes on the camera seeing the changes on the screen.
(2,758 Views)
Can you tell me why you don't want to use Vision assistant? I am curious
I think an option can be to use a LabVIEW example as grab.vi and see on "life" the changes you are doing.
(2,757 Views)
You can do the same operations with the calibration VIs in vision development module.
Amit Shachaf
(2,746 Views)
