Hello ,
maybe the problem that you are having is the following:
You must be sured that have checked "Start Inspection when Launched" option on the Startup Tab on the Remote Target Option. Doing that, you can turn off and on the CVS and the inspection will start working according to the digital port selection (connect a screen to the VGA port of the CVS ). Test to change the digital inputs and the inspection will change.
But the problem is: if you go to Vision Builder - Inspection, stop the Inspection running and start again, the CVS ignores the digital port selection.I mean, if you start an inspection from VB for AI, the CVS ignores the digital port selection. The inspection must be launched by the CVS.
I hope this helps.
